I just finished doing this a couple weeks ago. I replaced my evap and heater cores with units from Performance Radiator. Shipping was quick, and they looked like quality units. At least I hope they are cause I wouldn't wish that job on my worst enemy. Took me about 7 hrs. to get it done. If you are doing it solo, like I had to, do yourself a favor and remove the door ajar switches from the a pillars. Chances are high you will break one, or both, when you remove the dash. Replace the receiver/dryer while you are in there. Mine had about 4 ounces of dye in the bottom of it. I found it easier to remove the passenger seat and the front portion of the console. If yours is a manual, the shifter is easy to remove to get out of your way. I reclined my driver seat an put the console on there.
