AC Replacement
crossx5
Ohio
So I recently discovered that on my Jeep I purchased over the winter that the electrical connection to the AC compressor has been disconnected. So I am assuming the worst, that the compressor has gone bad. Has anyone used the AC compressor and component kit from RA? The manufacturer is GPD. Or should I just stick to a remanufactured MOPAR compressor and parts from NAPA?
thanks!
Any help would be great; did u figure which to purchase? I wanted to go with a kit but am ordering pieces separately
Last year I purchased all factory components. Id recommend spending the money (expensive) on factory parts if you determine that components need to be replaced.
Reactions: CES22
I did get a rebuilt compressor hopefully it will go in smoothly ill try to update on it after Friday fun day
