When I got my TJ it had a 3 inch lift which as far as I know consisted of taller springs and shocks, I believe all of the other suspension components were stock. I did notice that the tires protruded out further on one side than the other by about an inch. I can’t remember which side however because since then (over the winter) it was in the shop having a leaking pinion seal replaced under warranty when they recommended that my front track bar be replaced with an adjustable one due to my lift. When I got it back I noticed that the tires appeared to be centered (front & rear), it looked much better.
Another thing I noticed however was a tendency for the Jeep to pull slightly to the left on the highway, that was new following the installation of the new front track bar. Could this be happening because the front axle is properly centered & the rear isn’t (although they appear to both be centered I’m guessing the rear is not given its stock track bar & I'm not sure exactly where to take real measurements from to confirm). Or, do I even need to bother measuring anything at this point, in other words do I need an adjustable rear track bar given my situation? If so what parts do I need? Front is an adjustable BDS if that’s relevant.
