I dropped the transmission cross member / skid plate and discovered this rust, only around the 3 bolt threads on each side. There is pretty much zero rust in the rest of the car so this is disappointing.
From my search it seems like a common problem? Is there a common solution and even more hopefully a simple solution?
Is the washers-between-frame-and-crossmember the recommended long term fix?
Thanks.
Thanks.
