Replacing my control panel for AC/Heat. It was only blowing in 2 speeds. Works great except now it only blows out defrost. Pretty sure before I did this that it was only blowing out center vents. I can not find a bad place in vacuum line from engine, followed through T and into firewall, also checked one that runs under battery until it disappeared. Before I pull battery and box out, and before removing dash; Is there anything else I should check? Arms and connectors from actuator are moving by hand and not broken. Wait….. Works fine with engine running to create vacuum. Leaving this here for education and humor. Yep, okay to laugh with me
