Airing up with ARB compressor?
Westtown Willy
TJ dummy
Clown World
I know my ARB compressor is set up to air up tires & the company says it can handle up to 35 inch tires but does anyone here have experience regularly using one of these for that purpose? I always use the air station as it's very fast & convenient but sometimes the line can be horrendous, the other day I used my own air line & it worked well, took maybe twice as long but got the job done (33x12.5 from 12lbs to 26lbs).
I ask because the main reason i have this is for the lockers & I don't want to burn this thing up airing up out of convenience... Here's the one I have, they call it the hi-output compressor:
A compressor doesn't need to put out any CFM at all to engage lockers but they have to put out a lot of CFM, at least 1.5 to 2 CFM, to fill up big Jeep size tires within a reasonable amount of time. What model ARB compressor are you using? The smallest/slowest compressors are fine for ARB lockers but not for refilling big tires.
Not to mention I wouldn't want a small compressor performing double-duty on lockers and filling tires... filling tires is hard on a small compressor and it may not stay reliable for use with lockers where it needs to work every time.
Reactions: FTI76
that is my biggest concern, it looks really small & I was never comfortable with the idea of airing up with it; its primary purpose is to assure my lockers work when i need them which is far more important than saving time not waiting in an air-station line... just trying to confirm that this is a valid concern on my part.
The model is the ARB High Output Onboard Air Compressor, according to their video it's the middle model, this one:
https://www.quadratec.com/products/...ObAD7cG9mwVdpcD3EWV6XOMSEN0s5TaxoCdX0QAvD_BwE
Years ago I had front and rear ARB's, and I bought the extra kit for airing up tires, but it was so slow and the compressor would get so damn hot that I ended up buying a portable V-air as suggested before. It works so much faster and better. I also bought a Longacre racing aluminum tank. It fills the tank super fast and the tank is super light and has a gauge on it.
I am in the market for an onboard v-air kit soon because i don't want to carry around a compressor and a tank. I want it all on board.
I have the CKMA12 and use it to air up my tires after wheeling. I don't get to wheel often as work and life gets in the way plus my TJ is built for rocks and I don't have them down here in South FL. I also use it around the house to top of our other vehicles from time to time.
thanks all, I think I'll just keep doing what I've been doing which is to use the on-site air up station for the tires & keep the air hose in the tool box for trail emergencies only. The long line situation is the exception & there's also the gas station a couple miles from the park...
that's actually what made me think of this, when I went to disconnect the hose from the compressor it felt like a frying pan blackening some fish, shocked the hell out of me how hot that thing got; thinking that can't really be a good thing
Reactions: ac_
Hi @Westtown Willy ,
I do purchase the ARB CKMA 12 and paired with a 2.5 Gal tank, the plumbing is 12MM ID with one quick connect on the front bumper and other on the rear. I do use a check valve between Pump and Tank to isolate both process. I will never been airing up when lockers are in use or vice versa so I do feel comfortable with the set up.
My ARB CKMA air up two sets of 33 x 12.5 (11 psi to 28 Psi in less than 10 minutes. It's get hot, not going to say is not but part of that is that I do mounted on the tray below the master cylinder and there receive a lot of heat from the exhaust manifold.
What model number is your ARB compressor
Jorge I've got the same one, the CKMA 12; that sounds like a pretty elaborate setup you have there. I go from 12 to 26lbs on the same size (33x12.5), the one time I did it this past weekend it took about 2 minutes per tire, the air station takes about 45 seconds so I thought that was pretty good for such a small compressor but like I said, HOT, probably could've fried an egg on that thing :D
This is the set up I went with. Have had it about 5 years and its been working great.
https://www.amazon.com/dp/B000YC42RG/?tag=wranglerorg-20
Reactions: ac_
I run a CKMTA12 with a 1gal tank. I used to use it for my front locker, swat bar disconnect and airing up tires. I had it mounted under the hood on the back of the driver side fender (above the tray) I had 2 failures in 2 years and it killed my ability to use my locker for the day. After the second warranty repair I moved it inside the cab to help keep it cool and used a CKSA12 to run the lockers and Sway bar. This gives me the best of both worlds, reliable air for my accessories and available air for my tires.
I have friends who use the same compressor as you however for both regularly and have no issues. I opted for the greater redundancy. If my small compressor dropped dead I could top up its manifold from the big one every few activations and keep going for the weekend.
There must have been a time
when we could have said no.
I have the same one that you have on my CJ and have used the heck out of it for several years now without a problem. It also works the lockers in my front and rear diffs.
Just recently, in order to speed things up, I made my own CO2 tank inflator. I bought a tank off Craig’s list for $40 and a regulator and guard off eBay for $60. For a tad bit over $100 I have tire shop inflation speed which I can move between my CJ and my TJ. It can also run air tools and the tank can be refilled at a grow shop for around $7.
Hard to beat.
Reactions: Fouledplugs
I also have a CKMA12. It takes roughly 2 min to inflate my 35x12.5x15 inch tires from 12 to 25 psi each.
I would like to put a compressor on my jeep for airing up low/flat tires while out on the trail/road. I don't know what is best and what all will be needed. Any ideas?
For those that have quick access to a jack, taking the load off a wheel whilst airing up dramatically reduces the load off tank less compressors.
I carry a cheap compressor with me in case of a puncture, but tend to air down and not bother airing back up on the trails. Takes too long and the compressor gets super hot. And driving hope aired down is a super plush ride after a long day of hard wheeling :D
