Alignment problems with Currie steering
GeorgeSully
South Carolina
So I just installed my Currie steering kit but while trying to do an alignment I’ve found that the clamp on the tie rod bumps into the drag link and won’t allow the tie rod to turn all the way around. Ive got the Jeep on jack stands but they are under the axle so it’s at normal ride height. I have a 98 Sahara with no lift.
Doesn't the Currie steering need 2" of lift or more to clear? From Currie's website,
"NOTE: This unit is designed to be used on vehicles with 4" of lift. It can be used on vehicles with less lift, but the vehicle must have a minimum of a 2" bump stop (over stock). Also, on vehicles with no lift, 2 of the tie rod ends may need be trimmed to achieve proper adjustment."
This is what I was thinking
The currie Steering on my 2004 TJ (4" lift) is the same. I just removed the bolt and nut until I got the alignment like I wanted it. Then replaced the hardware. I put the bolt in so the head was on the side of the drag link of more clearance. I wanted to stay "in the groove" and was successful.
There is a flat spot on the bar that the bolt is supposed to ride in. That is what is keeping it from spinning fully around so it won’t hit the drain link. Use a slightly smaller diameter grade 8 bolt and it will spin freely.
