The alternator in my 2001 4.0 seems to be on the fritz and on its way out. What's the go-to brand? Currently, it has the OEM Denso 56041864AA. Thank you!
I'd stick with something from your local NAPA store and not worry about a special order from a catalog store.
NAPA seems to have Bosch or the NAPA Brand, Is one preferred?
This. Get one from a local store so you can swap it out on their parking lot if needed.Since it's a simple 10-15 minute job, go with the one with the best warranty.
I just did the Durango alternator install and it was a direct swap, no belt or pulley change.Make sure you swap your old pulley into the new alternator as the TJ stock alternator pulley is a smaller diameter, as is the crankshaft pulley.
https://www.rockauto.com/en/parts/remy,94116,alternator+/+generator,2412
No clue as I did the swap in the parts store parking lot when it failed on a trail ride. Everything I've read on the swap doesn't mention changing the pulley.Was your alternator pulley the same diameter? The Durango stock alternator pulley is slightly larger. You'd still be able to get the original belt on; you just wouldn't get as much power at low or mid-RPM.
