Am I using this sunrider top right?
Yetigain
California MD
Hi all and happy Friday.
I bought my Jeep with this top that I guess can fold back like a sun roof. Question is am I using it right? It doesn’t seem to fold back as far as I would think and it sags a little too much for my liking (I’m 6’3” and it’s a bit close to my ballcap).
Is there more to it that I’m missing?
Reactions: K0LCB
If I’m not mistaken, you can pull the two pins (one on each side) and fold it back onto itself once more. The pins are on top of the door surrounds.
Reactions: Yetigain
Thats as far as it will go. However as MountaineerTom said, you raise the header a bit and fold the material under it and over itself to give a bigger opening.
Also, the latches if you flip them towards the header (rear of jeep) there should be a like a strip that's cut out that you basically latch onto to hold the latches firmly and from bouncing around.
Reactions: Yetigain
There is suppose to be a strap that you use when folding the top back to keep the top from flopping back on you and to also hold the fabric from flopping around. I put my SunRider top on my daughters TJ so I'll try to get a picture of it for you.
Reactions: Yetigain
