Amazon shop
DoOver
So Cal
P0128 popped up for me on the way back from Lowe’s. The hoses and cooling system have been on my list since buying the Jeep. I would like to support the site and purchase the hoses, thermostat, and coolant from the amazon store but, didn’t see them listed. Did I miss them or, are they not available?
I thought Chris said as long as you opened Amazon ap from a link on this site anything you then purchased helped the site. I hope so that is what I did when recently bought all parts for my cooling system.
I'm sure it's impossible for @Chris to add everything anyone would possibly need for their TJ to the store front, but it's my understanding that once you've followed the link to the store, anything you search (even if it's not in the store front) for and purchase in the main search will go towards supporting the store. That will have to be confirmed though.
Also, any amazon link posted on this forum gets the store ID added to it, so if in doubt you could always post the link here and follow it.
My shopping list that I derived from https://wranglertjforum.com/threads/jeep-wrangler-tj-cooling-system-overhaul-faq.3397/
Belts and hoses are of course year/engine/accessory dependent and I didn’t follow the recommendation to use Mopar water pump. Time will tell if that bites me in ass but the Gates fit perfectly and addressed the coolant puking problem my LJ was having.
Prestone AS105-6PK Radiator Flush and Cleaner - 22 oz, (Pack of 6) https://www.amazon.com/dp/B00B99U074/?tag=wranglerorg-20
Stant 45359 SuperStat Thermostat - 195 Degrees Fahrenheit https://www.amazon.com/dp/B000C7YRNM/?tag=wranglerorg-20
Stant 10234 Radiator Cap - 18 PSI, Single https://www.amazon.com/dp/B000B8JUG6/?tag=wranglerorg-20
Gates 22900 Lower Radiator Hose https://www.amazon.com/dp/B000CHGIA2/?tag=wranglerorg-20
Gates 23183 Coolant Hose https://www.amazon.com/dp/B000UOE1XS/?tag=wranglerorg-20
Gates K060882 Multi V-Groove Belt https://www.amazon.com/dp/B000C2YCJG/?tag=wranglerorg-20
Thermocure Coolant System Rust Remover, Safely Removes the Rust from Cars Cooling System, 32 oz Bottle https://www.amazon.com/dp/B00R74I5UY/?tag=wranglerorg-20
Stant 25160 Thermostat Gasket https://www.amazon.com/dp/B000C847YU/?tag=wranglerorg-20
Mopar 5503 7652AA, Radiator https://www.amazon.com/dp/B0049EH4AC/?tag=wranglerorg-20
Gates 42293 Water Pump https://www.amazon.com/dp/B000C2U77C/?tag=wranglerorg-20
Zerex G05 Phosphate Free 50/50 Prediluted Ready-to-Use Antifreeze/Coolant 1 GA https://www.amazon.com/dp/B0033QQ4VW/?tag=wranglerorg-20
I think any time we post an Amazon Link in the forums it automatically adds the extension that credits WranglerTJ
Look at all the links above: tag=wranglerorg-20
Do keep in mind that Amazon's search SUCKS, and is getting worse! When in doubt, use google, it "usually" gives more pertinent results.
Reactions: RobertJ
All the cooling system parts (and their respective Amazon links) are located here:
Jeep Wrangler TJ Cooling System Overhaul FAQ
Unfortunately, most of those parts are no longer made by Mopar. I've noticed that all the 97-02 stuff is for the most part gone, while the 03-06 stuff still is for sale, but in very low quantities. Get it while it lasts, because once it's gone we're at the mercy of the Chinese.
As for supporting this site via Amazon, see this thread:
Help out this website with all your Amazon purchases. It's free using a simple add-on extension
