Shine some light on this please.
So a month ago i got the engine light with two codes P0153 and P2098 which i read might be an o2 sensor. I got suggested to change all four which i did and with NGK. Light went off drove it to work today, it's about 60 miles round trip and i get an engine light again code P2096 now, to lean. read up on it and it might be an o2 sensor again. I read on here where Jerry said might be the catalytic converters that might be bad and it's giving o2 sensors faults.
Questions
If it is the catalytic converters that are bad can i drive the TJ with the light on without causing any harm or will that cause a problem on the jeep?
Hopefully i can drive it until i get funds to replace it. here in California starting price for an approved one is about $700
Or should i yet buy another o2 sensor pertating to that code amd change it in hopes it goes away?
Also could a manifold leak be a cuase as well?
I have attached some audio video with sound of my motor in idle and in drive. Does it sound normal?
I will post one during day
Thanks in advance
In idle park
In drive
Questions
Thanks in advance
In idle park
In drive
