With Blaines’ guidance I went through the entire bleed process tonight now the lines are solid-
-removed, plugged and bench bled the master - rock hard push with 1/8” travel. Rigged a plug like Blaine advised -
- verified the push rod is set correctly
- reinstalled the master
- bled each wheel in correct order with the correct “crack bleeder-down- tighten bleeder-pedal up” method
- reseated the pads
-all that is left is to crack the bleeders tomorrow for residual air, although this round I’m not even seeing them.
Result- outstanding brake performance.
Like be careful with them. I like to drive a tad aggressive when no ones around and these really suit that.
Come in as hot as you want. She’s stopping and doing it quick.
Pull out in front of me.
Whatever. I like big brakes and I cannot lie.
I’m going to go ahead and get this in the open now- From here on I will be promoting Blaine’s brake kits. They make people safer. They could save the life of a child chasing a ball into the road (seen that first hand). I know guys think the stock system is ok for big tires,
then eat up pads and rotors to the point they keep spare sets around. Once you have big brakes, you get it.
Blaines’ character, product and knowledge have me sold.
As a really nice surprise when I was under the rig I put my magnetic flashlight on the painted black control arms - it fell off. That means they are either wood or aluminum.
As far as I can tell there is not one cheap part or compromise on this LJR.
This thread healed a wound, fixed a jeep, and increased my knowledge which means growth.
I appreciate everyone helping and attempting to help,
@Artsifrtsi for being willing to come out on a weekend,
@psrivats for cutting to the chase
@Weasellee for reaching out- and of course Blaine jumping all over the problem.
Likely a burp later at the calipers will increase performance, and new parts are coming- I may not change the lines instantly, just for short term closure- or I might while I remember how to do all this.
I will add if you think you are an authority on bleeding brakes, ask yourself exactly how you know that. Question when you aquired that knowledge. Ask yourself if its correct, does it apply to all brands and models. My point is, even with great intentions, we all get on here and spout what we “know”....but it is possible to be off base - and one of the worst things about that is it closes our minds to searching for accepting the right knowledge. With brakes being serious business, that is something to consider. I know I will from here on.
I will always try harder now to keep someones’ mechanical aptitude, means and ability in mind as I post what I think will help them.
