I was reading through some old threads and see some conflicting opinions on the Dana 35 27 spline axle shafts. I was looking at the thread from 2018 called "Dana 35 beefing up" where Jerry recommended the 4340 27 spline (over 4140 since the 4340 is a little stronger) to a person in the Dana 35. Just a minute ago I read a thread from 2019 where Jerry advised against the 4340 as the bearings can cause failure to the axle shaft. I was just about to order some 4340 splines but I thought I remembered this thread somewhere. I am wanting some stronger axle shafts for my Dana 35. I was intending to go the super 35 route, but I don't have the funds to add a nice locker such as the detroit or the ARB with it along with regearing. So, I am thinking about buying chromoly 27 splines and getting a truetrac (I've read a while about the limitations of them but I think it will work OK for me) put in the rear. Maybe a powertrax no slip put in the front Dana 30. Currently, I am on 32 inch tires that are brand new and have the 3 speed auto with the I6. I am planning to go 4:10 gears so it will work with my current tires; however, I know that ratio is optimum for 33s. At the moment I really want 35s in the future and will likely add either a 4 inch kit with progressive springs or a 3 inch lift with a small body lift. I just want to make sure the axle shafts I get (likely the 27 spline 4140) are good enough for 35s if I decide to go that route in another year or two. Also, I would think the 4:10 gears would still work well with 35s. I know it the preferred ratio for the 33s, but it definitely can't be anything as bad as my 32s with 3:07s. Overall, the 32s and 3:07s aren't too terrible just the acceleration is slow and is terrible on hills. I have moved to the mountains for graduate school and there are a few pretty decent grades on the highway where I have to get in the big truck lane and top out at 45 mph unless I manually shift to second gear. Then I can get to about 55-60 reving around 3000 rpms. I don't like doing that though because I know I am putting a lot of strain on the transmission and gears.
