I have a 1998 TJ Sport, 4.0 5-speed, purchased a few weeks ago. The HVAC blower fan was not working when I bought it. By not working, I mean nothing. No fan regardless of any switch or control settings.
I read lots of threads on fixing similar problems and replaced the fan switch, the resistor pack, the blower motor with no change in the symptoms.
This is the old style slide control panel, not the newer panel with multiple knobs.
Today a friend and I went through the schematics and systematically tracked power through the circuit. We had good power and connections everywhere.
Clearly there was something in the ground circuit that was not passing enough current to run the fan.
We cut the black wire that goes to the blower motor from the relay and resistor and connected it directly to a ground point.
Everything now works exactly as it should.
The question is, what and where is the ground problem that we bypassed?
No melted connectors were found anywhere. We interchanged old and new components without any change in results.
We had 12+ volts at the connection for the blower motor, but the motor wouldn't turn. Both blowers worked fine direct-connected to the battery terminals.
As a hail-Mary final play, we connected one of the blowers to the positive side of the connector at the firewall and ran the negative from the motor to the negative battery terminal. It worked! And all the controls worked too! We had 12+ volts at the connection for the blower motor, but the motor wouldn't turn. Both blowers worked fine direct-connected to the battery terminals.
