My first TJ is breaking me in, nicely.
It's hard to start, pretty sure that is the fuel pump (Check valve). What is stumping me:
When it does start, from cold. It sounds like it's running on 4 cylinders (Its a 4.0) Pop the throttle and idle it up and it smooths right out. In high gear (3spd auto) with the converter locked, at approx 35mph with the throttle position just off idle, it acts like it runs out of fuel, loses a lot of power, then will start pulsing like I'm pumping the throttle as I'm going down the road. If I mash it to the floor, it will sputter and then pin you to the seat with acceleration. After that it runs fine until I start driving in the same manner again. If I drive it a little more aggressively, or on the highway, it never stumbles.
I've replaced the TPS, MAP, and, IAC Valve......Any ideas? Is the fuel pump causing this?
Thanks, Heath
Thanks, Heath
