Another TJ on 37s thread
I personally can’t stand the stuff. And I don’t like that wham bam weird crap that’s everywhere so I drink white man Mexican in Premier
I don’t blame you unless I’m at the brewery drinking it.
Is magnum powers still around? And if so does it require moving ac compressor. Thanks
Saw this earlier after realizing I couldn’t get one. Hence: f that cable lol. But thanks
The reason the cable breaks is the cable release loop is NOT the pull handle to flip the seat forward. When you pull on that loop to flip the seat forward, it binds the folding mechanism release and stresses the cable. The correct way to do it is with two hands. One on top of the seat to push it back slightly to free up the release mechanism and then pull the loop. While holding the loop under tension, use the other hand to tip the seat forward a couple of inches and then release the loop.
Using the loop to flip the seat by itself is about the same as towing the rig around by the hood release. It isn't made for it.
I can’t seem to load their website. Is there a vendor I need to go through?
No, you can only go through their website. The last time I checked it was about a month ago. Hopefully nothing has happened since then. I know Charles is an older guy so I hope he’s still alive.
Reactions: custommuffler
I’ve read and read your posts about them for the past few years. I value your opinion and following your advice as boosted tech is next option. Have a 5.7 LS out of a burb but I’m tired of this Jeep and just want easiest least amount of stress option
I have the boosted tech setup. Leave it stock or V8 swap it.
I haven’t ever been able to get magnumpowers.com to load. Ever. Not in the past or today
I would highly advise against Boosted Tech after my experience with them. If you can find a Banks turbo kit, that would be the far better option 👍
Phone, Firefox, explorer, edge….. nothing. Multiple phones here have tried. Reckon stock and maybe the LS swap in the next life. I’m done working for this TJ
  • Face Palm
Reactions: IPerkWVU and Alex01
First rinse off of spider webs
