Took me about 4 hours for the first one, then 2 for the second one...came out decent
They were the Paramount Brand...cheaper than the others, but surprisingly very well made. Had to replace the drives side "jeep rust " fender, so went with these...giving them a try...I'll keep everyone updated on how well they stand up for elements...thanks for asking!
Does Paramount make a matching style fender for the rear? Also, how do the hood latches mount to that fender?They were the Paramount Brand...cheaper than the others, but surprisingly very well made. Had to replace the drives side "jeep rust " fender, so went with these...giving them a try...I'll keep everyone updated on how well they stand up for elements...thanks for asking!
I have the new LEDs arriving today, thanks for the tip on the side marker lights. I had to get new latches since I had to cut one bolt because it spun on me. You just use the existing holes from underneath from the existing dense as a template.
Doesn't this tube fender replace the 'existing fender'?existing fender holes from underneath as a template for the latches
No I didn't order the flasher module...I didn't do my homework, rushed order...I'll have to check the lights when I get home. Thanks very much for the help...do you have part number or vendor where you got yours?
- You want dual function led which will work as both running light and a flasher, I think the ones your ordered have only 2 wires based on the photo
- There are 4 and 5 pin flasher relays - what year is your TJ?
