I am finally getting around to installing my CB stuff, and I'd like to mount the antenna on the swing away tire carrier, routing a ground strap to the rear crossmember. It will take ~30" of strap to route to the crossmember as shown.
The problem is I've read that the ground strap should be as short as possible. Is 30" too long?
Also, are any other potential problems mounting the antenna so close to the metal carrier? (part of the height of the antenna runs along side the height of the tire carrier when mounted here)
I do have a teraflex tail light mount, but I'll admit I'm not too eager to drill through the tub, in case I ever want to uninstall or mount the antenna elsewhere. I'd really rather mount the antenna to the carrier, but I'll use the tail light mount if I have to.
