When using anti sieze for a mild steel bolt into a mild steel thread, which flavor of anti sieze should i be using? i understand theres different temperature ratings, but for work on fender bolts, fender flare bolts, suspension related bolts.. just your normal everyday bolt outdoors (not stainless or aluminum bolts) what would best be recommended? Being up here in the rust belt area of Michigan with lots of summer humidity and salty winters id like to be able to take apart fittings without a major fight in the future rather than "gluing" them together with aluminum based and causing a galvanic reaction.
i had been using aluminum anti sieze for years now because thats just whats been on the shelf of chemicals in the garage. i began thinking aluminum based may not be such a smart idea as aluminum and steel react. My sisters first car was a Dodge Omni and i remember the rear bumper was aluminum and held on with steel bolts and one day the galvanic reaction actually worked it way deep enough to cause the bumper to fall off.
Yesterday i made a trip to the local bolt and screw supplier Mid-States Bolt & Screw Co. who are pretty good for having whatever replacement fastener you need on hand and was recommended nickel or silver grade.. but the employee wasn't fully sure and pulled out the sales book and just kinda pointed and said for the most part "i think these would be your best bet".
i picked up a jar of silver anti seize because honestly i figured it would be better than aluminum but honestly im not too sure if thats what i should be using or not.
any recommendations? or is there something else similar i should consider?
