Good day gentlemen,
A fellow Jeeper is having a technical issue with his Jeep and I would like your input…Here is his issue:
The problems have been going into limp mode far too often, jerky up shifting, little down shifting in 4 low. On advice from transmission shop, had solenoid pack installed – helped with these problems but still there
· One month ago drove up to Western Sierra – two long steep uphills. Went into limp mode four times on the way up. Worked fine while rock crawling at low speeds in 4WD for four days. As soon as hit pavement went into limp mode and also three more times on way back
· Your PCM installed
· Drives fine around town – but did before – not really testing conditions
· Drove almost same route last week. Only went into limp mode once on the way up and twice on the return – all times on steep up hills. No problems off road for five days. Off road in 4 low changed down much better (used to not want to change down into first, so I had to do this manually) and changed up well. First time I’ve had this “automatic” working well off road. On road changes up without being jerky and changes down smoother than it did.
Hopefully this is a good write up of my issues, what has been done, the testing I did, and what problems are still there. This is mainly going into limp mode. If you need any clarification please call me.
Any suggestions would be very helpful.
All the best,
Mark
All the best,
Mark
