32 inchFor what size spare tire? Many of them locate the spare tire further away from the tail gate it is mounted onto which places a lot more stress on the tailgate and its hinges.
Um, I think you need a new phone first
Thank you Jerry. Do u recommend this over a bumper with a tire carrier attached? I do need a new bumper because mine is smashed on one size. Also need a hitch mount.I just looked up your tire size Kathy and the OE factory spare tire carrier isn't up to carrying a 33" spare. My factory spare tire carrier cracked and failed within about 6 weeks after installing a 33" tire on it. And while that Rugged Ridge carrier is stronger than the OE carrier is, it doesn't beef up the tail gate or hinges like the below recommended Exogate carrier does. Plus it likely positions the spare tire further away from the tailgate which applies more stress to (leverage against) the tailgate and factory hinges.
I'd go with Brantley's suggestion and install an Exogate spare tire carrier which is more than up to that size tire. One thing that's nice about the Exogate is that you don't have to unlatch it first to open the tail gate, it swings open with the tailgate.
This one... https://gr8tops.com/shop/jeepmodels/wrangler-lj-2/tj-lj-exogate
Absolutely, not many tire carriers attached to a bumper are built all that strongly. Most are flimsily designed and the hinge-point the swing-out rests on is seldom all that beefy. With the Exogate, you can run any bumper you want. Check out the US made $169 rear bumper with an integrated receiver hitch at http://www.thedirtworx.com/_p/prd13/1638368235/product/rear-bumper which is what I've run on two different TJs. High quality with a very beefy receiver hitch, especially given its low price.Do u recommend this over a bumper with a tire carrier attached? I do need a new bumper because mine is smashed on one size. Also need a hitch mount.
I can vouch for this bumper. Very strong, mounts like it's supposed to, and looks great, and have already made good use of a very well-made hitch receiver:Absolutely, not many tire carriers attached to a bumper are built all that strongly. Most are flimsily designed and the hinge-point the swing-out rests on is seldom all that beefy. With the Exogate, you can run any bumper you want. Check out the US made $169 rear bumper with an integrated receiver hitch at http://www.thedirtworx.com/_p/prd13/1638368235/product/rear-bumper which is what I've run on two different TJs. High quality with a very beefy receiver hitch, especially given its low price.
Always like seeing the Dirtworx rear bumper without the tire carrier on other TJ's. Only wants me to make that purchase faster than I need too!I can vouch for this bumper. Very strong, mounts like it's supposed to, and looks great, and have already made good use of a very well-made hitch receiver:
I will most likely add an Exogate tire carrier down the road. I've even had two very beefy integrated tire carrier/bumpers (that were very pricey) on previous Jeeps, and got really tired of opening them separately.
I don't agree with Jerry, putting 400$ towards a bumper with carrier could get you easily into the money needed to over come his complaints. Especially when you need a bumper anyway. A good bumper with.. can go for 7-900$ a cheap bumber is still 300$
Sent from my SCH-I535 using Tapatalk
So the Exogate actually comes with a spare tire carrier? I was told that it did NOT come with the actual tire carrier.
It doesn't. But I bet Kathy probably has a fine stock carrier. Most people scroll through Quadratec and fall upon the "HD carrier" deal and think it's sufficient for larger tires, not considering the actual strength of the tailgate or hinges.
Or, maybe her stock carrier is falling apart in which case the Exogate would require her to buy a new carrier piece. I don't know.
$400 bumper/tire carrier combo, while nice when new, will not last. Someone will likely chime with 'I've had mine for X years, no issues', but the general consensus is that those type just do not last, especially the hinge setup; been there, done that. If you really want a well-made bumper/tire carrier combo, it's going to set you back upwards of $1k or more. Then you still have to deal with opening the tailgate and tire carrier separately, although there are versions that integrate with the tailgate and open together. I have had both. FabFours, great bumper, with tire swing, but really got tired of opening them separately. Expedition One, another great bumper/tire carrier, this one opened with the tailgate, but would tend to come out of adjustment, and was a bit noisy at times. Both were over $1200.I don't agree with Jerry, putting 400$ towards a bumper with carrier could get you easily into the money needed to over come his complaints. Especially when you need a bumper anyway. A good bumper with.. can go for 7-900$ a cheap bumber is still 300$
http://rover.ebay.com/rover/1/711-5...0001&campid=5337789113&icep_item=222543873434I'd like to get the exogate, but I threw out the factory carrier a long time ago. I'd have to buy one then.
I have seen several on Craigslist.I'd like to get the exogate, but I threw out the factory carrier a long time ago. I'd have to buy one then.
