got it . thanks , you know ill haveThe only area that needs RTV sealing is the snout the housing end interface. Once that is sealed, it is just like a typical big bearing Ford Set 20 application and the seal takes care of the rest.
Snout interface is define as that round part left after you cut the seal snout off. That is a press fit into the hole in the new housing end. Smear RTV around the clean round part that looks like a short tube that the housing end will press onto. Think of it like sex. The new housing end is her, the little short snout left is you, the RTV is the condom.
you know ill be thinking about that duringThe only area that needs RTV sealing is the snout the housing end interface. Once that is sealed, it is just like a typical big bearing Ford Set 20 application and the seal takes care of the rest.
[/QU
you know ill be thinking about that during install. haha
