I have a 4 inch suspension lift and 4.56 gears. Presently run Toyo MTs 295/70R17 (load range E), which the manufacturer 33.5. They measure 32.5 installed (ground to peak) on my Jeep.
I’m leaning towards load range C, KO2s (315/70r17) which are 34.4s. I’ve seen some members post installed measurements of of these tires in the neighborhood of 33 and 33.25.
Its common knowledge that a 4 inch lift is fine with “33s”. But these are considered 34.4s. If I go with these KO2s and they end up measuring between 33 and 33.5 on my Jeep will I experience any rubbing with my 4 inch lift?
