Atlas questions
Akitadog
Willy's Edition
The "209"
Been digging around the jeep sites trying to get some answers on the questions AA asks when ordering a case.
Next week will be ordering an Atlas II trail series transfer case. I have a couple questions though.
Atlas-2-Speed-Trail-Series​
Select Options:
Application: 2006 TJ w/ 6 spd.
Application Variation: 2006 non-rubicon
Drop: Drivers side
Gear Ratio: 5.0:1
Tailhousing : Standard w/ speedo
Will my stock speedo cable work here?
Rear Yoke: 1310 or 1310 CV?
Front Yoke: 1310 or 1310 CV?
I have the 1310 joints, but also have the cv joints both drive drivelinesines. which would be the correct answer?
Speedometer Module:
Not sure if I need something here or will the stock unit work?
Shifter Kit:
I currently have a Novak cable shifter, will this work?
I hope some can help me out here or explain some of this?
Thx
sierradmax
RI
You want standard with speedo provison tail housing.
You want 1310 CV yokes. You'll be lengthing the rear and shortening your front driveshaft.
Need AA's mechanical housing for the speedo module. Call then up and tell them your tire size and axle ratio, they'll tell you which gear you need for accurate speed.
Your shifter (assuming for the 231) is no good. Now you'll have two shifters. I used the 97-02 for auto trans in my 05 with the 6 speed. Works fine.
Akitadog
Akitadog
Willy's Edition
The "209"
So the Novak will not work...Bummer.
The other answers help answer my questions.
Thx
