Morning,
Question regarding son's Jeep. Noticed recently I could move the shifter/trans selector out of Park with the key removed. Surprised, as I didn't expect to find that and believe (if I'm reading tech manuals correctly) it shouldn't be "allowed." However, with the key in the "Run" position and engine off, the brake pedal must be depressed for the shifter to move out of Park.
Question: Should the shifter/trans selector remain locked in Park with the key removed? Appreciate any advice on next steps if not operating by design. Service manual excerpt from Trans section on interlock system is below:
"The system locks the shifter into the PARK position. The Interlock system is engaged whenever the ignition switch is in the LOCK or ACCESSORY position. An additional electrically activated feature will prevent shifting out of the PARK position unless the brake pedal is depressed at least one-half an inch. A magnetic holding device in line with the park/brake interlock cable is energized when the ignition is in the RUN position. When the key is in the RUN position and the brake pedal is depressed, the shifter is unlocked and will move into any position."
Thanks,
GSO06UNL
Thanks,
GSO06UNL
