My TJ is not a daily driver so it will often sit a month or more before being driven. When I took it out last month it drove and shifted fine, no issues at all. I got in it yesterday and it started right up per normal, but I could not shift into reverse. There is play in the shifter from side to side but it will not go to the far right where reverse should be... but it gets even weirder. The clutch engages as normal, but when I put it in 1st - 5th gear and release the clutch it does not move, I cannot release the clutch fully without it dying, it seems like it is binding. When I release the clutch with the shifter in neutral it acts like it is in first gear. I have play in the shifter from side to side, but it drives like it is in first gear. With the clutch fully engaged it idles fine. I have not worked on transmissions before, any thoughts or things to check before taking it to a transmission shop?
98 TJ, 4.0, AX-15 Transmission
