First post on here. I have a 1998 TJ, 2.5L ax5. I completely blew my 231J tcase last week. I replaced it was a 231J from a 98 cherokee and after reinstalling everything and filling up the trans (redline MT90, 3.5 quarts) and tcase(atf+4, 2 quarts), my transmission won't engage in gear at all. I can slide my shifter in any gear with clutch depressed or pressed with no resistance but it remains in neutral. When in reverse there's a faint grinding noise. Any advise would be great. This happens with engine on and off. When driveshafts weren't installed everything seemed to operate correctly, output shaft would rotate when spinning front shaft pinion by hand, wouldn't spin when in neutral, etc. Thanks
