tjroughrider Member Original poster Joined Dec 15, 2016 Messages 94 Location Winnipeg, Manitoba, Canada May 20, 2017 #1 Will a 98 Cherokee Dana 35c axle fit a tj Dana 35c? Sent from my SM-N910W8 using Tapatalk
Rob5589 Certified video trained differential rebuilder Supporting Member Joined Aug 29, 2016 Messages 6,691 Location W Sacramento, Kalifornia May 20, 2017 #2 Cherokee has leaf springs.
Jerry Bransford No Longer Participating Supporting Member Joined Nov 9, 2015 Messages 29,734 Location Fleming Island FL May 20, 2017 #3 Rob5589 said: Cherokee has leaf springs. Click to expand... tjroughrider said: Will a 98 Cherokee Dana 35c axle fit a tj Dana 35c? Click to expand... Not without being converted from its leaf spring configuration to a coil spring configuration. That takes a lot of cutting, grinding, and welding plus a mess o' brackets onto it to make it possible to bolt up to a TJ.
tjroughrider Member Original poster Joined Dec 15, 2016 Messages 94 Location Winnipeg, Manitoba, Canada May 20, 2017 #4 I need to replace the axles not the whole diff. Sent from my SM-N910W8 using Tapatalk
Rob5589 Certified video trained differential rebuilder Supporting Member Joined Aug 29, 2016 Messages 6,691 Location W Sacramento, Kalifornia May 20, 2017 #5 tjroughrider said: I need to replace the axles not the whole diff. Sent from my SM-N910W8 using Tapatalk Click to expand... Ohhh. Yes, they will work.
Jerry Bransford No Longer Participating Supporting Member Joined Nov 9, 2015 Messages 29,734 Location Fleming Island FL May 20, 2017 #6 tjroughrider said: I need to replace the axles not the whole diff. Click to expand... Oh, you meant the axle shafts.
tjroughrider Member Original poster Joined Dec 15, 2016 Messages 94 Location Winnipeg, Manitoba, Canada May 20, 2017 #7 Yes Sent from my SM-N910W8 using Tapatalk
