I wanted to get some insight on this. I just replaced my alternator as I had just replaced my PCM because the voltage indicator on the dash would die while driving. I replaced the alternator a few days ago and the voltage on the dash is fine now. But I’ll turn the Jeep off and go to turn it on and it doesn’t crank. I have to get jump starts off my old lady to get it to crank. I tested the voltage on the battery with a voltage tester and got the regular numbers 12,13 so on. And also tested the alternator which gave me 13.8 which I believe is normal. I thought the alternator was faulty but I got it to crank earlier after jumping it off and then removed the negative from the battery terminal and the Jeep ran fine still. Reconnected, turned it off, *click* nothing. I got a new battery in early summer 2019.
Insight here? Could the battery still be bad even though it’s reading good voltage? Would replacing it fix this issue? Thanks!
