2005 Jeep TJ.
Rubicon
6 speed manual.
66000 miles
Noticed with engine running, voltage at battery is 15.5 V.
With engine not running, voltage at battery is 12.5V.
Charging system Gauge on dash shows 14V.
No check engine light.
Did multiple searches on this topic and tried the following.
1 cleaned both positive and negative battery terminals.
2 cleaned ground connection at battery- goes to chassis center bolt on firewall. And alternator.
3 cleaned chassis ground connection located on center bolt of firewall
4 cleaned ground connection at alternator.
All resulted in no change.
Voltage is still reading 15.5V
Note- there is no check engine light on.
There are no noticeable performance issues.
As I understand it, the alternator output is set by multiple parameters including engine load, battery charge level among others.
Any suggestions?
Would replacing alternator fix this or do I need to address this with PCM fix?
Should I consider external voltage regulator?
I plan on checking engine ground.
With no observable performance impacts, is there a problem with leaving things as is?
Will alternator life be reduced.
Will battery life be reduced?
Thanks in advance.
Rubicon
6 speed manual.
66000 miles
Any suggestions?
Thanks in advance.
