Spectra Premium from Napa has been fine for my uses. I’d prefer Mopar but I’ve run the Spectras with no issues at all.
Does anyone suggest electric fans and shrouds?
Rock Auto
1994 Jeep 4.0 radiator (copper/brass construction)
CSF 2576 2 Row - Going for $270 at the moment
Do not waste your money on the 3 row. No added advantage, Wranglers actually seem to run better with the 2 row
Will fit all Jeep Wranglers from 1987 to 2006
Avoids the cheap Chinese aluminum knock off problems
I'm surprised this hasn't drawn more discussion.
I have a theory (obviously no hard evidence to support it though) that the biggest reason that the aftermarket “performance” radiators fail is not because of coolant pressures or temperatures, but more simply just flex in the body.
If you look at the radiator and the A/C condenser, they have very different mounting systems. The A/C condenser is mounted with the use of rubber isolation mounts which allow a small amount of movement between the grille and the condenser. However, the radiator is directly bolted to the grille.
The OEM radiator is probably designed for a certain amount of flex, or at least happened to pass testing. The aftermarket designers may not be aware of this, and simply adapted their other (otherwise successful) designs to the TJ.
If this is true, I would suspect that adding flexible mounts to an aftermarket radiator would significantly increase the lifespan of that radiator.
Another (similar) idea could be that the aftermarket radiators do not have adequate flexibility to accommodate the thermal expansion and contraction from routine use, and simply develop cracks and eventually fail instead. Essentially, as the radiator heats up, it expands, but the grille it is bolted to is the same size. Thus, the two end up imparting a lot of stress on one another, and the radiator, being made in part or wholly with aluminum, fatigues and eventually pops.
If I had to choose an aftermarket radiator, I actually would try one of the name brands like Mishimoto. But I would 3D print some flexible rubber mounts rather than mount it using the OEM bolts. More generally, I would make sure that it is free to flex in any direction, be it caused by thermal expansion, body flex, or even just vibration.
Which part?
The concept of using a YJ radiator that might be more robustly constructed and more easily repaired. The 2 row thing isn't what grabbed my attention, but being that it's copper may make up the difference vs a 1 row.
Copper and brass in traditional construction methods suffer from the Achilles Heel that is lead solder with its horridly low thermal transfer rate. I'll reserve my testing and evaluation of them when they finally bring the new tech brazing and laser welded versions to market for automotive.
Oh, yeah that's no good. I would bet that's why this flattened tube style was never big in HVAC until they started making them from aluminum. Round tube/plate fin heat exchangers are mechanically bonded by expanding the tube into the fin so we don't have that issue.
Blaine are there any high-end high-quality all aluminum radiators made for the TJ that cool as well as the Mopar for those where cost is not an issue?
I have a single row radiator in my 2000 jeep wrangler 4.2 now. Works fine below 90s but won't handle the heat. Puked the other day at 96 deg. After shutting it off in the Popeyes chicken place. Looked outside and watched it. I don't want to ruin my 2000 wrangler 4.2 with only 60,000 original miles. Her.
Ummmm, did you retro fit that 4.2? Because out TJs have the 4.0 in them.
Ok, maybe it's a 4.0, original engine.
Same Napa brand that I mentioned in my post.
