Best compromise gear ratio: 97 TJ, 4.0 automatic
Jun 30, 2016
20
4
#1
Just going to file this away for future reference at this point.
My daughter has a 97 TJ, 4.0 auto, 3.08 gears. What would be the best compromise gear ratio for her currently running 31's but maybe in the future going to 33's?
Her Jeep is a daily driver but she does enjoy doing trails here in Colorado. Occasional hiway use as it is a DD, but mostly just around town.
I'm asking because I keep an eye out for Dana 44's and if I ever got lucky and found one with the right ratio I'd probably snag it.
Dec 8, 2018
11
5
Greenville, SC
#4
I agree with 4.10 for 33" tires. I had a '97 with the 4.0 and auto - I put 4.10s and 33" tires on it initially. It was ok, but I later switched to 35" tires and wished I had gone with more gearing in the diffs.
I now have a 2004 Rubicon which came factory with the 4.10s and 31" tires. It has the 5 speed and I've decided as I go through my build that I'm keeping the 4.10s. My plan is 33" tires with the 3.5" MetalCloak short arm lift. I really considered going with 4.56 but I wanted to be able to drive it on the highway. My feeling is, for wheeling, the 5 speed with the 4.10s and 33" tires will be great and will keep it reasonable for any kind of highway driving (I no longer have a tow rig nor do I have a trailer...)
I found that for wheeling, the auto was a bit of a pig even on the 33s with the 4.10s - however, I was living in Utah and mostly using my rig as a trail rig (trailered for the most part). For daily driving, the 4.10s are probably fine (with the auto) especially if there are a lot of highway miles.
Robb
Jun 30, 2016
20
4
#5
I wish my girl would just try to learn how to shift a manual, but no go what so ever. Pity but that's why I hunted for a long time trying to find her a nice 4.0 automatic.
I'll keep my eye open for anything 3.73-4.10 and consider myself lucky if I can find a deal.
Robb
Jun 30, 2016
20
4
#7
What I meant my compromise was best for both. Currently have 3.08's and running 31/10.5 15's and MAYBE 33's in the future.
Just looking for a good compromise on what would work for both/either for now and in the future.
My daughter has dreams but who knows what will actually develop.
Rob5589
Certified video trained differential rebuilder
5,883
5,425
W Sacramento, Kalifornia
#8
That was my point. Why spend 1500+ dollars for something that will work well for 31's but not so well for 33's? 33's are a whole different animal than a 31. Increased weight, width, resistance, and rolling diameter. A "compromise" would be finding some used axles with 3.73, which is a very common ratio, and go from there.
astjp2
368
165
Utah and Alaska
#9
Well you could think outside the box, leave the 3.07, install a tummy tuck, drive it for a while, and then work on deciding what tires you may want. I went with 34's and 4.11 in my YJ but my tranny does not have an overdrive so it works good for me. I have lots of clearance and lots of ability to do what I want. My wifes's old TJ had 235's on it, we went to all kinds of trails and had a blast for a daily driver. We just knew that we would not be doing anything rough with DOT tires.
Jul 16, 2018
25
16
Gadsden
#10
I can speak from experience thanks to the advice I received on this site. Re-geared my 2000 4.0 auto with 285/70/17 (33s) to 4.10s and it is by far the best modification I've made to my TJ. Perfect manners for all my driving conditions. Obviously it's not a compromise setup but one tailored for 33s. Not sure if that helps any.
Rob5589
5,883
5,425
#12
Go with the 3.73's you will probably find in the used D44's your looking for, then when you decide to go to the 33's you can re-gear to 4.56 in those axels without new carries needed.
4.56 and 33's is a bit too deep on the 3 spd auto, unless you are willing to keep hwy speeds down to around 60. 70 is 3300 in drive
