What’s the best thing I can do to the frame to keep it from rusting (“park it” is not a good answer)
Do the whole frame in POR15 and then undercoat it, or fluid film. That's the route I am taking before winter comes.What’s the best thing I can do to the frame to keep it from rusting (“park it” is not a good answer)
Degrease > Wire Brush > POR-15 > Flat Topcoat Paint > Fluid Film. I did exactly just that last weekend. Took a day and a half for one rig.Do the whole frame in POR15 and then undercoat it, or fluid film. That's the route I am taking before winter comes.
Same Answer sand blast and Zink Oxide DipWhat’s the best thing I can do to the frame to keep it from rusting (“park it” is not a good answer)
In my experience 45 to 65 is ideal. It dries overnight if you leave it out in the driveway. This year is my 1st time to use fluid film, read it from one of Chris thread. I am a linseed oil user for 20+ years.Any concerns using POR15 when temps get below 50 degrees? I see that's the lowest recommend curing temp.... It's already cold in Indiana
Can you post some underbelly chassis photos for us to see? I may just do what you do. I am living in IA an apartment right now and no garage to do all the linseed oiling. Reason why I use the fluid film for this year for it does not drip.All the coatings in the world won't beat washing it weekly. For surface rust, coatings will help some. But if you want to prevent internal frame rot (which is the biggest concern when it comes to TJ's), washing the inside of the frame twice a week is your best bet. It'll last forever that
Personally, I don't put any aftermarket coatings on my Jeep and I never will. Just wash the underside as much as you can. If it is warm enough, I'd just throw a sprinkler under the Jeep in the driveway. If it isn't warm enough, just head to the do it yourself carwash and go to town. I don't drive my Jeep all that often, so I'm going to start washing out the underside every single time I take it out in the winter.
Can you post some underbelly chassis photos for us? I may just do what you do. I am living in a apartment right now and no garage to do all the linseed oiling. Reason why I use the fluid film for this year.
"All the coatings in the world won't beat washing it weekly"
Boy, look at what you just said - you broke my heart my man. You are trying to advise us, TJ enthusiast and all, proud with your way of taking care of your rig, which you believe that it's better than how we do ours. Now you confessed that your frame is rotted out. WTF?
But you have a f-ing rotten frame my boy!Maybe if your reading comprehension was a little better, you would understand that I haven't been the one taking care of my TJ for most of its life. It wasn't washed once for 14 years while it sat in salt, so it rotted out. If the frame was regularly washed out like I recommend, it would be in perfect condition. If you think coatings are the way to beat rust, then by all means, coat your Jeep. I base my opinions on the extensive research that I've done regarding frame rust. Also, answer this. How did the factory coating hold up to salt? If coatings are the way to beat rust, why didn't the coating that Jeep put on at the factory work?
Frame rust is not hard to beat if you pay attention to it. If you don't pay attention to it, like my Dad didn't, you end up with a rotted out frame.
I have used linseed oil for over 15 years and do not have a rotten frame. That is a fact. You on the other hand has a rotten frame and that is a fact.
I wonder how well the inside of the frame is coated at the factory to begin with. I'd guess it's far less than 100% coated.
I do believe washing it out helps but I'm sure how much it helps varies depending on how often it's washed and how long it stays "clean"? Washing regularly helps considerably more on days that the road is dry than on the days we end up driving through some slush on the way home from the car wash.
On the other hand, washing may cause problems to coated surfaces by removing the coating. When it ends up so clean that it's uncoated that can't be good
