I have some 3/16 6061-T6 corner armor I need to cut. For those of you who have cut aluminum with a jigsaw, what is your favorite blade?
I just did that last weekend. I used a 12TPI Diablo blade at very slow speed (trigger barely pressed), and it worked very well. I tried blades with small teeth and faster speeds, but the teeth gummed up in every other situation. Using the 12TPI at slow speeds, I was still able to cut it fairly quickly. I'm guessing it took about 5 minutes to cut one wheel well.
Aluminum tends to stick to your blade and fill the collets - that’s the main problem In my experience. When I cut aluminum, I always use regular old bath soap. Touch it to the moving blade every few minutes and it works great Keeping the blade clean. It also does not make a mess like cutting fluid.
I use it on the band saw as well as the jig saw.
I did use TapMagic-Aluminum on it.
The thing with aluminum is heat. It melts at a much lower temperature than steel. Just like welding it, cutting it is all about minding the heat!
Another good product is Eastwood’s “Grinder’s Grease.” It’s very similar in consistency to a soap. I use it with Rotabroaches and die grinders with burrs, like when porting heads - basically any time you’re cutting at higher speeds.
I’ve seen where people use beeswax for aluminum but I myself haven’t tried it.
