The one you build yourself.....that is my favorite....
I agree 100% with all of that.Agreed on putting the jack across the rear of the cage. This assumes you need one on the first place. I don't know anyone who actually wheels their jeep that carries one.
I bought a carrier that holds two jerry cans thinking I would use it all the time exploring Colorado. 5 years later, I rarely make use of it. I have never needed the extra gas when I thought I would, but never had it with me the few times I could have needed it. Regardless, I have never run out of gas anywhere despite having put in over 19 gallons more than twice. I did pick up a 5 gal water can that I will carry far more than a gas can.
If you really feel the need, find a carrier that keeps the cans low and close to the tailgate behind the spare.
My swing out doesn't sag and is easy to close. However, I did need to completely redesign the entire latching mechanism from the dumb method the manufacturer came up with.
Sometimes I do think about changing to slimmer and lighter carrier and bumper than what I have.
I have to assume then that yours uses some sort of high quality bearing in it (maybe something similar to the unit bearing you'd find on a TJ front axle)? The cheaper ones I've seen may not even have bearings, I'm not sure. All I know is that all of them sagged and didn't open very smoothly.
The hinge is a trailer hub with two big bearings on a thick spindle.That's the only problem free part of the carrier. While it never sagged, it did bounce terribly until I added a shim to the latch side. And the original latch was idiotic. Nate's 4x4, btw. Somewhere in my build thread I discuss it more, along with my various fixes over the years.
jjvw said:Agreed on putting the jack across the rear of the cage. This assumes you need one on the first place. I don't know anyone who actually wheels their jeep that carries one.
jjvw said:I have never needed the extra gas when I thought I would, but never had it with me the few times I could have needed it.
My jeep is a daily. Constantly carrying 33lbs of spare fuel and a 25lb jack to the grocery store doesn't work for me. Maybe if I lived in Alaska.
. . . I have yet to see a single rear tire carrier bumper in which the tire carrier isn't starting to sag, or isn't difficult to open. . . .
My Rock Hard 4x4 swing-away tire carrier doesn't sag, even with a 35" tire and two filled jerry cans, nor does it rattle. It is easy to open and close - one finger operation.
I can't take credit for the purchase, the prior owner of my jeep gets that, but I can say that it is by far the best commercially made bumper/tire carrier I have encountered. Bonus points - it is made in the U.S.A. with U.S. steel. Not cheap, but worth the price.
The spindle and hub for the swing-away arm has dual tapered bearings and races with a zerk fitting to keep it greased:
It has a spring loaded safety pin to keep the tire carrier from closing when parked on an angle:
One finger operation for the latch (the same latch assembly is used on ambulances and fire engines):
