I’m looking for some new factory ride height springs for the front and rear and im wondering what you guys have used or recommend.
98 Sahara 4.0
98 Sahara 4.0
I just had moog problem solvers installed (moog 3227 and 3226), I have a stock height 4.0 as well. Paired with rancho shocks and I'm very happy with the results.
Edited to add that I found my springs in the thread from Rob that is mentioned above.
So ive ordered the Rancho RS5000x shocks for my stock 2003 TJ and looking to pair them up with appropriate "stock" coil springs. This jeep will be driven unloaded, no top, stock bumpers, no significant extra weight / gear. Im looking at the Moog #'s 3227 and 3226 coils per the forum discussion but have read that these particular might be "stiff", or that they are Rubicon springs and not the sport / x moog coils. Im looking for a replacement coil spring set to upgrade the rusty old ones and help to create a smooth on pavement ride and to handle / smooth out washboard gravel n dirt roads. Are these moog coils (3227/3226) the right coils for my basic stock needs or ? Thanks for a bit of input. CheersCorrect, Moog 3226/3227
Thanks. I appreciate the input. Im looking forward to see the difference that the ranchos make. Not having put on shocks or springs before i have to read up on the process. Am i right that they realistically should be installed at the same time?Pretty sure the deal is that they're spec'd for 4.0 engines/auto transmissions. Also if you plan on adding weight (I.e. A winch) they are made to bear that additional load. I believe they're what you want and I don't find them to be particularly stiff. Someone said pairing them with Ranchos gives it a more truck-like ride and I think that's accurate.
Members will tell you that shocks determine ride quality FWIW. I've been running them with new ranchos for a couple days now tho and I'm loving it. Much more stable ride, I honestly am more impressed with the stability improvement than I am with the way they absorb the jolts on crappy roads
98 Sahara 4.0
h&r springsI’m looking for some new factory ride height springs for the front and rear and im wondering what you guys have used or recommend.
98 Sahara 4.0
Sent from my iPhone using TapatalkI’m looking for some new factory ride height springs for the front and rear and im wondering what you guys have used or recommend.
98 Sahara 4.0
h
98 Sahara 4.0
Stayed the same height, or did you lose some?I have a set of JL springs you can have for shipping. They are stock height...they sure didnt lift my LJ
Thanks, It just reminds me that I need to practice welding before I can try to outboard my shocks...Nice job on the front BPE.
