Got the jeep back from the shop, man alive the difference between stock gearing and 5.13s is ridiculous, I was hopeful but I was not expecting this, it is a night and day difference and feels like a different motor.
I’ve been doing a couple little projects today, adjusted my tv cable because it had a bit of slack, decided I should check on my throttle body since I have a cheap “cold air intake” that I did with the highlines. I was taken aback by just how much dirt had already built up in there, does anyone have any suggestions for an air box, I saw @mrblaine did an intake through the headlight, if you wouldn’t mind dropping a couple more pics if it’s not too much of an ask, did that setup work well, I know there were concerns on how turbulence might affect airflow?
That’s much better, I’ll be honest I didn’t notice the engine running any better and it still has the slight misfire that it’s had since the swap but at least I have some piece of mind that it’s cleaner now.
