Zorba "The Veiled Male" Lifetime Supporting Member Joined Apr 2, 2020 Messages 23,927 Location Merritt Island, Fl Apr 22, 2023 #21 Move to Florida. Nobody uses turn signals here anyway. Reactions: Blondie70
Jeff Jeff Jeff New Member Joined Apr 29, 2023 Messages 3 Location Auburndale Florida Apr 29, 2023 #22 Biologistjim45 said: Did you ever get this fixed? I ama having the same issue. Click to expand... I had the same issue. Ended up being the brake light fuse. Under the hood, fuse 27 marked MFSW. Reactions: Stretch97 and Chris
Jeff Jeff Jeff New Member Joined Apr 29, 2023 Messages 3 Location Auburndale Florida May 1, 2023 #23 Jeff Jeff Jeff said: I had the same issue. Ended up being the brake light fuse. Under the hood, fuse 27 marked MFSW. Click to expand... Correction... This is not actually a brake light fuse. MFSW stands for multi function switch. It powers your turn signal switch and relay.
06TJ35's TJ Addict Supporting Member Joined Mar 17, 2018 Messages 2,607 Location Los Angeles, CA, USA Oct 20, 2023 #24 Jeff Jeff Jeff said: I had the same issue. Ended up being the brake light fuse. Under the hood, fuse 27 marked MFSW. Click to expand... Jeff Jeff Jeff said: Correction... This is not actually a brake light fuse. MFSW stands for multi function switch. It powers your turn signal switch and relay. Click to expand... This fixed my turn signals.
old Dog2 New Member Joined Nov 18, 2024 Messages 1 Location Massachusetts Nov 18, 2024 #25 Zorba said: Move to Florida. Nobody uses turn signals here anyway. Click to expand... Massachusetts isn't better with lack turn signal usage. Of alot not using the in Florida are more likely former Massholes!
Zorba "The Veiled Male" Lifetime Supporting Member Joined Apr 2, 2020 Messages 23,927 Location Merritt Island, Fl Nov 18, 2024 #26 old Dog2 said: Massachusetts isn't better with lack turn signal usage. Of alot not using the in Florida are more likely former Massholes! Click to expand... But do they cut corners?
Stretch97 (Formerly Duner) Supporting Member Joined May 6, 2020 Messages 618 Location Buffalo, New York Aug 28, 2026 #27 Jeff Jeff Jeff said: I had the same issue. Ended up being the brake light fuse. Under the hood, fuse 27 marked MFSW. Click to expand... You are goated for this comment, I was about to lose my mind. Checked this fuse and it was blown!!
