Bolts through top of frame okay to hold skid plate?
I don't *think* you will have any issues with doing it this way, though it would've been much better if he had welded pipe in between the lower frame repair and the upper frame to prevent crushing. Looking at the amount of rusted material, it looks like the welder would've had the room to do this. I would imagine these bolts will be much more likely to work loose however, so I'd keep an eyeball on them. Also, drilling holes in the frame (now you have upper and lower holes, obviously weakens it, something else to keep in mind. I wouldn't have done this, but I don't think it's the end of the world. I mean, he could've drilled holes in the new lower plate he welded on, and welded bolts pointing downward to bolt the skid on (like studs). This would've been a better approach assuming the material he welded on was heavy enough, and overlapped enough good steel where he welded it. He may have gone through the frame because he wasn't confident his repair will last.
The thing I don't understand is that if your frame is this bad at the skid, I can't believe there aren't other serious issues of rust. I mean, this is some serious rot. I'd take a hammer to all the common rust areas and hit em' a few times to see what gives. It would be extremely unlikely that the frame would've completely rusted out around the skid but not, say, at the usual rear lower control arm mount area.
yeah that’s why I didn’t want to do a frame swap because everywhere else is solid and practically no rust. There’s some rust on the bottom inside the frame above the rear control arms, but I hit around there and it’s still solid. The whole front and past the rear control arm is all good tho. The guy did all the welding for a shop that builds and does all kinds of customizations for Jeeps, I think he did a good job with the welding, it’s just how the skid is held up. I’m probably gonna order the bolts and nutserts
Pull one of the bolts and measure the diameter of the hole he drilled and see what size nutserts you are going to need for that size hole. They may be bigger than factory. If you can't get anything that makes sense because the holes are just too big now, I'd probably just run it as is, It should be ok. The frame is already a repaired frame, so if you are comfortable with the fix, I wouldn't go killing myself to make it "right" as it would take a frame swap to really make it right. Just drive it and enjoy it.
Just my $0.02.
