I took my trim panel off my 2001 to to replace some loose clips. Why does the bracket behind the trim panel not line up with the pull straps? Is it so same door can be used with different trim/ years? Full doors, by the way.
Ohhh, that makes more sense. Sorry, it was kinda hard to picture what you were referring to.
Your pull handle bracket is upside-down. The side of the bracket with less distance between the edge and the mounting screw should be at the front of the door. You have it mounted pointing at the back. It's one of those "D'oh!" moments.
Check out the way the mount is attached to the door in this video. He pulls the panel up at about 7:15.
It had oversized silver screws holding the strap on. Kinda figured something wasn’t right. Now to find the original type black screws. Thanks again. Just swapped the bracket around, now to get the clips and put it back together.
Most auto parts stores sell a version of the u-nuts that are a little different. They are flat and don't have the barrel shaped portion that the screws goes into like the MOPAR ones. I'd think they would probably work just as well if you get the proper sized matching sctrews.
The correct name for the part that Mopar uses is extruded U nut. Extruded means the metal was punched to extrude it to make the barrel that can be threaded. There are lots of styles of U nuts and nut clips.
