My question is, what size is the whole in a brake disc for a 1/2" wheel stud.
The reason for the question is I am swapping a high pinion Dana 30 into my TJ and at the same time doing a faitly common modification in the UK by using Grand Cherokee (WJ) knuckles, whih allows use of the larger WJ brake discs. To do this I need WJ discs redrilled to 5x4.5" pcd. I have found a company that can supply the discs redrilled, but they are now coming back asking what size the wholes need to be. I did ask them to simply drill the same size wholes that are in their TJ discs, but I guess they are looking to ensure that if it is wrong it is my fault not theirs, so they still wanted a size from me. I have told them the studs are 1/2" and asked them to drill the whole size they would normally use for a 1/2" stud, but I'm worried they will drill a 1/2" whole and that this could cause fitting issues.
Thanks in advance for any help.
