Lots questions are asked and answers are sought on forums, but many times when the matter has been resolved the solution is not posted. This is a summary of the procedure and the resulting solution to my problem.
Issue: Weak Rear brakes. While on jack stands, in gear at an idle, the rear brakes could not keep the rear tires from turning. At a speed of 20-30 mph (on the jack stands) the brakes would stop the tires but without letting off the pedal, the rear tires would begin to spin again.
1. Checked brake lines and Calipers for any crimps or leaks.
2. Bled brakes then tested. No change.
3. Re-bled brakes then tested. No change, called Blaine.
4. Turned key on and bled brakes clearing the Brake-Light warning after each pedal push removing air, then tested. No change, called Blaine.
5. Checked brake fluid pressure at Master Cylinder's two outputs and the three combination valve outputs then tested. No change, called Blaine.
6. Removed Master Cylinder, bench bled, replaced then tested. No change, called Blaine
7. Purchased new Dorman Master Cylinder, bench bled, installed, and tested. No change, called Blaine
8. Removed rubber cap from the combination valve plunger, re-bled then tested. (Rear brakes worked better, but the pedal was spongy.
9. Replaced rubber cap to combination valve plunger and re-bled.
9. Checked vacuum at the brake booster (14-28 in HG). Hooked up vacuum line from my 16' Ram 1500 (20 inHg) then tested. No change, called Blaine and Jon Schaefer from RPM Extreme.
10. Replaced brake booster with a brake booster from buddies TJ then tested. No change, called Blaine.
11. Used a 3/32" cooper washer in combination valve to compress spring, re-bled then tested. Success! Called and thanked Blaine.
12. Ordered VANCO Big Brake Kit, rear Centric rotors, rear Black Magic Brake pads, and an orange Master Cylinder Cap from Black Magic Brakes!!
Needless to say, Blaine was a HUGE help. I placed an order with him today, however he informed me that he was happy to help and would have helped if I would have never placed or intended to place an order with him.
Thank you to everyone that gave input. Special thank you to Blaine Johnson of Black Magic Brakes!
