I'll get on it. I know my pads are just ok, so maybe BMB pads coming soon to a Jeep near you! But hopefully next year, when I can afford it. The Just Empty Every Pocket saga continues...I do not think you are supposed to add fluid. Fluid gets low purposely as the brake pads/shoes wear down. Once fluid level gets to a certain point then the brake light appears on the instrumental panel notifying you that brakes need serviced.
It can also get low due to leaking brake lines, fittings, wheel cylinders, etc.
Check your pads and shoes for wear and inspect the rear wheel cylinders inside the drums.
The brake light on the instrument cluster is there to show when there is uneven brake line pressure between the front & rear brake circuits. If there's a difference in brake line pressure between them, a shuttle valve switch between them inside the master brake cylinder will light the Brake light on the instrument cluster. That typically means one of the two brake circuits is inoperative though sometimes it can just mean the shuttle valve switch is stuck to one side. It's not indicating low brake fluid or brake pad wear like some cars provide indications for.Once fluid level gets to a certain point then the brake light appears on the instrumental panel notifying you that brakes need serviced.
mrblaine said:The light wasn't on to indicate a low fluid level and that is a very important distinction because you can trip the light with a full reservoir. It only turns on when the shuttle valve is shifted and that only happens when differential pressure is high enough on one side to kick it over.
That tells you there is a problem, from there you need to find out what the problem is. Similar to the CEL, it only means you need to dig into it to diagnose the actual cause.
It can shift from low fluid, a leak in one side, too much travel in a wheel cylinder, sticky proportioning valve, air in the master with the reservoir full, improper bleeding procedures, and other things. Or, the dash light can turn on because you spilled your soda in the console and it glued the momentary switch in place.
