I have searched, read, and come to understand @mrblaine is the brake expert (and maker of BMB and other jeep components?). I can't seem to tag him, but would like to resolve the issue with my brake light staying on.
I am aware that it signifies that the shuttle has moved in the proportioning valve due to detected uneven pressure. I have attempted stomping the brake pedal.
The TJ came with new brake lines, and the brake light on. I have since replaced all other brake components bled the brakes to clean fluid, activated ABS with scanner, and bled the brakes again. Clean fluid at all corners, but brake light is still on. Pedal feels great, truck generally stops great but will lock the rear wheels quite easily, and the dash brake light is still on.
What is my next step to solving this issue?
After less than 150 miles on the new brake system there is no sign of leaking. I visually check wheel cylinders, calipers, rear proportioning valve, and master cylinder and placed dry towel under each component and connection while it sat In garage, the reservoir isn't losing fluid, and everything seems to functioning properly, but I can't get the brake light to turn off (unless I unplug it).
My abs light is also on, but the scan tool seemingly gets the module to function, but while driving it does not function. I would have to double check the actual code that comes up, but I am hoping that wouldn't affect the brake light.
