Hello, I use my tj for 98% DD, it has 33x10.5 tires. The TJ currently has the BMB pads with centric rotors, and I really have no complaint other than having to do the break-in procedure frequently for them to grab better than oem. Aggressive driving is not my thing, I tend to coast and then use light pressure to stop at traffic lights. So Im looking for good oem replacement that doesn't need that kind of procedure. Not sure what material would work best if ceramic or metallic, or maybe a semi kind of pad? The most off-road the TJ sees are flooded roads, dirt roads and mountain roads. Looking for some suggestions, thank you.
