I'm honestly just guessing/ballparking for the 6L80E. I've seen some guys on here with LS motors that have mentioned them and I see adapter plates that mention the GM stuff like the 4LXX stuff. I have done very little with automatic transmissions, but looking at gear ratios for the 6L80E I was excited, maybe the Ford 6R80 is similar which would be nice to have some options.
There's a part of me that would like to switch to a different transmission for my build so I can turn up the torque a bit. Also that .6X OD would probably even help my range slightly on the highway and the 1st gear for the AX-15 is just too fast for my liking. However it's expensive to change all of that stuff and the AX-15 is a nice size and it's ok.
Gotcha so I can add some clarification to some of these.
The Ford 6R80 and GM 6L80 are nearly identical in terms of gear ratios
Gear | Ford 6R80 | GM 6L80 |
1st | 4.17 | 4.03 |
2nd | 2.34 | 2.36 |
3rd | 1.52 | 1.53 |
4th | 1.14 | 1.15 |
5th | 0.86 | 0.85 |
6th | 0.67 | 0.69 |
Both transmission are great for a diesel swap, granny low first gears with two overdrives, one for highway speeds and another for interstate speeds, having 6 speeds will allow whatever diesel engine you put in front of it to stay in it's ideal torque band.
As for the adapter the 6LXX engines need an LS engine adapter, where as the 4LXX transmission and earlier, ie TH350 TH400 700r4 4L80e etc, are considered pre-LS engines, though I don't know what is different between to the two. That being said I know TDConversions has a LS adapter coming soon for $1199 US but I don't know when it's going to be released. I'm getting a custom TDI to Ford 6R80 made for my swap, I already have the transmission, controller, shifter and it's already mounted in my setup so it makes it much easier.
As for controllers I was able to find a controller for the 6L80 here:
TCM-2650 GM 6L50E 6L80E 6L90E Transmission Controller W/Harness GM 4L80E 4L85E (93+)TCM-2800 HarnessTCM
And here is the controller for the Ford 6R80 transmission:
USShift Quick 6
Another positive with the 6R80, and I'm sure the 6L80 has this as well, is I have engine braking in the lower gears as well, so I get the benefit of engine braking with a manual transmission with an automatic transmission which is awesome.
You will need either a custom adapter to the factory NP231 with a new input shaft, that is what I did for my NP231, it's a 31-spline input and I use a custom adapter as well. Alternatively you could go with an Atlas as well but that is expensive but an option.
Two other things to consider is both of these transmission are HEAVY, something like 220lbs, but there are compact in terms of length but somewhat large in terms of diameter, you'll need to verify your clearance to the tub.
Lastly you will need to run a bigger cooling line for both transmission, running to our factory TJ Wrangler radiators is not an option, the diameter of the inlet and outlet to the radiator is just too small. Again not a big deal but something to keep in mind!
Hope this helps!
Thanks
Grant
