- Joined
- Aug 6, 2016
- Messages
- 100
Last weekend I attended the Cal4Wheel event 'Winter Fun Festival 2018" held in Grass Valley, Calif. Although there was not much show due to the warm weather here in California, there were over 400 attendees and several groups that headed out into the local forests to run trails and look for some snow to play in.
So, I was in a group that had only been on the road for about 45mins, when we stopped to air down before the more challenging part. I noticed a strong smell of burning rubber when I stood outside my rig, and when I looked underneath I found a large groove had been worn into the inner sidewall of my 35" BFG tire, which caused the smell. Upon further inspection, I discovered that the entire rear upper control arm and track bar mount bracket had separated itself from the axle housing! This was causing the axle to shift sideways under the Jeep whenever I made a turn, and the tire rubbed against the upper spring cup causing a deep gouge in the sidewall.
So, since i only had a short way to go to get back to the start, and no on-board welder to make a better fix, I used some Home Depot ratchet straps to cinch it down and 2 more straps to center the axle left and right. I made it back to my hotel no problem and loaded the Jeep on my trailer for the ride home to Boulder Creek.
Here's a couple pictures of the temporary fix - I strapped around the trackbar and the axle to hold it vertically, then used the other 2 straps to hold it diagonally to the rear bumper tiedowns.
I've ordered new beefy brackets from RuffStuff 4x4, and am planning to fix it this weekend.
the new bracket:
https://www.ruffstuffspecialties.com/catalog/R1988-05-06.html
the new bracket:
