My rear axle upper control arm mounts are slotted similar to my front lower control arm mounts. It uses cam bolts to secure the upper arms in place. Does anyone know if a Johnny Joint Washer will fit the rear axle slots as well. They worked perfect on the front to help hold in grease and with the slot filled in it gave the control arm bushing more contact area with the mount. It seems after looking through posts many rear axles don’t have the slots but mine does and it’s from the factory that way.
