Has anyone figured out an easy way to replace the tabs that top mounting screws for the center bezel go through? Both of mine have broken off and gluing them doesn't hold.
I'll pop the ham rig out and pull the vent panel and take some pics. Its the two screws at the top of the center bezel that you secure after snapping it into the holes. they are on the very top edge parallel to the windshield under the vent panel that runs across the top of the dash.pics are helpful when trying to generate ideas.
i understand and i've seen them suckers a handful of times...................... but my old ass can't visualize it anymore.I'll pop the ham rig out and pull the vent panel and take some pics. Its the two screws at the top of the center bezel that you secure after snapping it into the holes. they are on the very top edge parallel to the windshield under the vent panel that runs across the top of the dash.
maybe a slightly longer tab? use the screw to pull the tab and the tab could clamp the top end. maybe, if there is and lip there you maybe bend the tab to grab it.
i can't visualize it. hard to guess.
@Wildman you got your bezel loose ya. got a thought on this maybe?
That is what I was thinking- even new they are reasonable. I try to do dash work in warmer weather too....to reduce the chances of breakage, but sometimes you can’t help it.Just buy a good used one they arent hard to find
FUN-NEY GUY!Install a double din radio so you can have a backup camera and gps up front. Crutchfield will sell both the radio and new center bezel for $400. @Zorba is planning the same thing for his new smartphone
I've bought jeeps from you before....why not do it right when the parts are readily available? Just curiousI found some scrap aluminum from another project. I'm going to cut it and bend it so I can rivet it to the panel all the way across. Then drill it for the screws.
