Thanks. This is very helpful. If I’m not mistaken the front arms are 18”. The arms I purchased and put a 1” off set in when I tried to mount in front of the axle are 18”. If all this is correct it appears as all I would need to purchase now is the TJ mounting brackets, new axle brackets and move it to behind the axle. My photo below, the arm appears to have the offset in nearly the same location as yours.
What back spacing does the TJ in that photo have? It looks like there is some tire to antirock arm contact.
Lastly, I assume you didn’t reply to the last post because I’m over thinking things with the front axle driver side at bump? If not I’ll continue to try to understand.
